NC30 Caliper brackets (brembo 4 pad)
matt_nc30
- Thieving Pikey Twat
- Bike owned: NC30, 2000 R1
Bought the SES caliper brackets from JAP4 to fit the brembo 4 pad type calipers on my 30
Went to fit them today to find the gap from the bracket to the fork mounting points are to far apart for 1 spacer per hole.
2 are required but this doesnt look right, and there isnt enough to do this for both calipers.
Any ideas whats wrong, have i got the wrong brackets?
Pissed me off as i drained all the old fluid out of my old calipers before checking all the bits
Matt
Matt
- vfrman
- Bike owned: NC30, 1098s
Re: NC30 Caliper brackets (brembo 4 pad)
Got any pics? I can't seem to get a good visual of your problem.
I cant visualise that either.. there are two common brackets though depending on calipers.. the one you need will be 65mm if i remember?
They just bolt on?
They just bolt on?
matt_nc30
Yeah, my brackets look like that but with out the raied step, mine are just flat.
The brackets fit the calipers fine, and onto the forks, but dont meet the forks as the gap is to wide.
Il get a pic up later to try and show it.
Have you got them backwards!? The brackets should bolt onto the forks and not the calipers if anything..matt_nc30 wrote:Yeah, my brackets look like that but with out the raied step, mine are just flat.
matt_nc30
The bracket attached to calier
The gap between the bracket and forks
Will only fit with spacers to fill the gap like this
Matt
Matt
matt_nc30
Matt
Matt
viper_biker
Sounds like you have the wrong spacers. Easy fix, just get in touch with Gavin and I'm sure he'll send you the replacement sized ones.
Aaah.. so they actualyl line up ok?
I've looked on the net and the 'brembo' adapaters seem to come with washers
As seen in this pic.. get in touch and you'll get some :D
matt_nc30
Yeah they are the brackets i bought, i have the spacers but need to be twice the thickness.
More like
Compared to the ones i have
More like
