NC30 Oil Cooler
jb1000rr
NC30 Oil Cooler
Post by jb1000rr »
Has anyone fitted a UK spec ( 3L or 3M ) oil cooler to a Jap spec bike? I'm particularly interested to know how the pipes connected to the engine block. It looks like the block on the Jap bikes have a blanking plate but without taking them off I can't be sure and obviously don't want to try if it's not possible.
Having fitted them, (if it is possible?) did you think that it was worthwhile or not?
Again, if it is possible then I need to get my hands on some oil cooler pipes and can't find the Part numbers so again anyone that knows those please pass them on.
Thanks jb1000rr
abrmoto
Bike owned: RVFx5,SP1,MV F3,C90,Firestorm
Re: NC30 Oil Cooler
Post by abrmoto »
I have a cooler and pipes, make me a offer if any good to you.
royster81
Re: NC30 Oil Cooler
Post by royster81 »
and i have a uk pump so all you need is the lines from the pump to the block,make me an offer and between aly and i you have 90% of the bits.
i run an oil/water cooler on my bike and have noticed it's benefits.
CRM
Admin NWAA
Admin NWAA
Re: NC30 Oil Cooler
Post by CRM »
I have a UK spec bike and apart from having good rads, it really does make a difference to the cooling overall. It seems that few extra CC of oil does make a difference
Re: NC30 Oil Cooler
Anyone thought of fitting a ZXR400 oil cooler? It's bigger than the Honda one
hunter
Re: NC30 Oil Cooler
Post by hunter »
I fitted an oil cooler to a jap import,had to drill the crankcases first.but engine was stripped at the time so no swarf problems.
Re: NC30 Oil Cooler
hunter wrote:I fitted an oil cooler to a jap import,had to drill the crankcases first.but engine was stripped at the time so no swarf problems.
Did you change the pump?
I fitted this little dancer with a MOCAL sandwich plate - simple.
banoffee
Re: NC30 Oil Cooler
Post by banoffee »
that's neat!
jb1000rr - did you buy the NOS one from ebay then? :roll:
hunter
Re: NC30 Oil Cooler
Post by hunter »
Yes CMSMJ1,i actually stripped a uk motor and rebuilt the guts into the jap cases
jb1000rr
Re: NC30 Oil Cooler
Post by jb1000rr »
banoffee wrote:that's neat!
Banoffee, no I didn't. I'm going to wait until I can find an HRC oil/water cooler and the HRC water pump cover, If they ever become available from somewhere?
