NC30 Oil Cooler
Re: NC30 Oil Cooler
No need to buy HRC, the CBR600F uses exactly the same type, (from memory the F4 but all seem similar) see ebay item 400049169624 or 330370617172 for example.
Then drill, tap and put in a barb into the flat spot on the water pump and fit another barb to the drain.
Druid
Druid
Re: NC30 Oil Cooler
This one :-)
Re: NC30 Oil Cooler
Royster81, When you say you have a UK pump is that the HRC water pump cover part number 19220-NL1-000?royster81 wrote:and i have a uk pump so all you need is the lines from the pump to the block,make me an offer and between aly and i you have 90% of the bits.
i run an oil/water cooler on my bike and have noticed it's benefits.
Yes is it available ie. for sale?Neosophist wrote:
This one :-)
- royster81
Re: NC30 Oil Cooler
no mate it's not the pump cover ,it's the whole oil pump unit that sits inside the motorjb1000rr wrote:Royster81, When you say you have a UK pump is that the HRC water pump cover part number 19220-NL1-000?royster81 wrote:and i have a uk pump so all you need is the lines from the pump to the block,make me an offer and between aly and i you have 90% of the bits.
i run an oil/water cooler on my bike and have noticed it's benefits.Yes is it available ie. for sale?Neosophist wrote:
This one :-)
druid is talking baout what i did to my bike ,read here and look at the picturesfastdruid wrote:No need to buy HRC, the CBR600F uses exactly the same type, (from memory the F4 but all seem similar) see ebay item 400049169624 or 330370617172 for example.
Druid
http://www.400greybike.info/newforum/vi ... php?t=2894" onclick="window.open(this.href);return false;
i used an oil/water cooler but bought the uk spec pump so i could mod my casings and run an oil/air cooler so i could keep my rad fan for when i get stuck in traffic
- royster81
Re: NC30 Oil Cooler
i have that kit as well,but sadly not for sale, just the uk pump.Neosophist wrote:
This one :-)
Re: NC30 Oil Cooler
hi all
looing at running some oversize pistons in an nc35 motor and lifting compression etc
after having read about standard rads not coping with the heat after these mods.
i looked in to more cooling but the oil cooler using the water would just put the heat strait in to the rads again.
so am now thinking of fitting nc24/nc30uk oil pump and opening up the casing oil ways for the oil rad.
anybody done this ??? thoughts really on the pros and cons ??
Re: NC30 Oil Cooler
^^ It has been done.
you also can use a Mocal sandwich plate cooler as I did and that will allow another air/oil rad to be plumbed in. I think this is the way forwards for the heat rejection.
Re: NC30 Oil Cooler
yes the castings are already in the block, you just need the nc24 oil pump and the little lines that link the pump to the front castings, drill them out and away you go
- micpec
Re: NC30 Oil Cooler
yup, this can be done (i.e. drlling casings) however, it's delicate. Or opt for sandwich plate like been proposed here above and added cooler or some gerd rads with some +35% extra cooling capacity (see here: http://mngforce.typepad.com/nc450vdev/n ... assis.html )
