Anyone got a carb balancer?
bikemonkey
Post by bikemonkey »
As above, has anyone got a carb balancer for 4 cylinders? I'd like to borrow it :grin:
Adapters for the NC30 would be amazing too.
Plus if you're not too far and willing, a bit of help wouldn't go a miss either :peace:
Thanks in advance.
speedy231278
Re: Anyone got a carb balancer?
Post by speedy231278 »
Supposedly you don't need specific adapters for the NCs as they use the same size vac take-off points as the other models. At least, that's what Carbtune say, so I'll be miffed if I find it doesn't fit when I do mine... lol
V4beermonster
Bike owned: Vfr400,gt750,vfr400/750cc
Post by V4beermonster »
Take carbs off and balance by eye using the 3 holes in the Venturi
Post by Neosophist »
Corret, the NC30 requires screw in type take-off adapters.
There are two common types of adapter threads used on most bikes 5mm and 6mm. I cant remember which one fits the NC30 but 4 of each type come with the mogan carb-tune when you buy it so you wont have any proeblems using.
scotjell
Regular Member
Bike owned: VFR400 NC30x2
Post by scotjell »
If using it make sure you get a good tool for getting in there to adjust!!!
bikemonkey
Might get a right angled screwdriver if need be, or just blow torch and bend one ;)
scotjell
Regular Member
Post by scotjell »
bikemonkey
Sod that, £16 or "modify" an old one I don't like? I know which I'd choose.
scotjell
Regular Member
Post by scotjell »
Just remember its the internals of these that turn and not the driver itself there is a shaft inside. Stops your pinkys and the back of your hand looking like the elephant man.
porndoguk
Post by porndoguk »
its and m5 thread for the vacuum points, sod fancy screwdrivers if you got small enough hands use a marigolds glove and a 7mm socket and use your fingers, thats how i do it its fiddly but doable
