Anyone got a carb balancer?
- bikemonkey
As above, has anyone got a carb balancer for 4 cylinders? I'd like to borrow it
Adapters for the NC30 would be amazing too.
Plus if you're not too far and willing, a bit of help wouldn't go a miss either
Thanks in advance.
Thanks in advance.
- speedy231278
Re: Anyone got a carb balancer?
Supposedly you don't need specific adapters for the NCs as they use the same size vac take-off points as the other models. At least, that's what Carbtune say, so I'll be miffed if I find it doesn't fit when I do mine... lol
- V4beermonster
- Bike owned: Vfr400,gt750,vfr400/750cc
Take carbs off and balance by eye using the 3 holes in the Venturi
Corret, the NC30 requires screw in type take-off adapters.
There are two common types of adapter threads used on most bikes 5mm and 6mm. I cant remember which one fits the NC30 but 4 of each type come with the mogan carb-tune when you buy it so you wont have any proeblems using.
- Bike owned: VFR400 NC30x2
If using it make sure you get a good tool for getting in there to adjust!!!
- bikemonkey
Might get a right angled screwdriver if need be, or just blow torch and bend one
- bikemonkey
Sod that, £16 or "modify" an old one I don't like? I know which I'd choose.
Just remember its the internals of these that turn and not the driver itself there is a shaft inside. Stops your pinkys and the back of your hand looking like the elephant man.
its and m5 thread for the vacuum points, sod fancy screwdrivers if you got small enough hands use a marigolds glove and a 7mm socket and use your fingers, thats how i do it its fiddly but doable
