running issue
scubasteve
Bike owned: 2xNC30's
Re: running issue
Post by scubasteve »
thanks for the link, got a multimeter so going to check the wiring system using this guide. i noticed in the guide it says you can check the electrolyte levels in the battery as an indication that the rectifier is not working correctly. Will i have to disconnect and remove the battery to check the levels or is it safe to do so with the battery terminals connected. Also does anyone have any ideas where i might be able to get a suitable bit of replacement pipe for my vacuum pipe. looks ok but like u say, best replacing it whilst im there as it does look a bit old.
magg
Bike owned: VFR400
Re: running issue
Post by magg »
Do not check the electrolyte level, there is no liquid electrolyte in a sealed lead acid battery, which is the type normally fitted to an NC30.
If your bike simply stops without warning then it more likely IMO to be electrical, a fuel problem would result in a slower loss of power. Might also be worth checking the ignition fuse, ignition switch and run/stop switch. A problem with any of them will interrupt power to the ignition system.
VFRkieran
Bike owned: NC30, NSR250, CBR600, TS125
Re: running issue
Post by VFRkieran »
steve85 wrote:thanks for the link, got a multimeter so going to check the wiring system using this guide. i noticed in the guide it says you can check the electrolyte levels in the battery as an indication that the rectifier is not working correctly. Will i have to disconnect and remove the battery to check the levels or is it safe to do so with the battery terminals connected. Also does anyone have any ideas where i might be able to get a suitable bit of replacement pipe for my vacuum pipe. looks ok but like u say, best replacing it whilst im there as it does look a bit old.
Rick Oliver sells replacement fuel pipes have a look through his stock list here: http://www.400greybike.com/files/stocklist.doc Loads of other parts for sale too and he is a top bloke!
scubasteve
Re: running issue
cheers mate, ordered one from him last night.
scubasteve
Re: running issue
All sorted, turns out it was the original suggestion of the vacuum pipe. Cheers for the helpful advice, wouldn't of know where to start. ordered a vac pipe from rick o and it was in my hands in less than 48hrs, spot on!
