running issue
- scubasteve
- Bike owned: 2xNC30's
running issue
hi,
looking for some advice with an issue im having on my 1993 nc30. Was out on the bike this weekend and all was well for the first 20 minutes or so when all of a sudden on a nice straight bit of road the bike cut out on me in top gear. I rolled to a stop and then tried starting it up again. No luck first few tries then all of a sudden it went. pulled away and by the time i changed into second it cut out again. Tried starting it, and again it took a few attempts but finally went and backfired. Went to pull away and as soon as it hit 3,000 revs just died. To cut a long story short i had to ride the bike home really slowly by putting the choke on and riding just using the clutch and the first 2 gears. As soon as i touch the throttle it just kills the engine. Had the fairings of today and checked for any loose connections on the battery e.t.c but nothing wrong there from what i can see. If anyone has suffered something similar or has any advice it would be much appreciated
viper_biker
Re: running issue
First thing is to check the vacuum for the tank isn't either kinked or doved.
- Deviant400
Re: running issue
viewtopic.php?f=62&t=27307
Re: running issue
As above.. Vaccum pipe or fuel tank breather.
- scubasteve
Re: running issue
Thanks guys, that's really helpful.
- scubasteve
Re: running issue
Bike doesn't feel like its running out of fuel then dying it just cuts out all of a sudden. At first I thought it might be electrical but when I took the fairings off the battery terminals feel tight and no obveous loose conections in the loom anywhere. As you've all stated I will check the vaccum pipe and breather first.
- VFRkieran
Re: running issue
TBH i think its worth replacing the fuel hoses anyway if you dont know how old they are. I had a similar problem looked at the vaccum hose and it seemed fine but thought id replace it anyway, problem sorted and it only cost about 6 quid from Rick o.
- Deviant400
Re: running issue
yep and at least you can rule them out and move on to the next thing ,carb strip clean (use cammo's guide for checking through the carbs) then you'll know the fueling side is in order , then possible electrics
guide here-----> viewtopic.php?f=24&t=14524
- scubasteve
Re: running issue
cheers guys, removed the fuel tank today and all looks ok with the vacuum pipe but like you say its probably best replacing it anyway. The breather pipe of the top of the tank is fine too, so looks ill have to take a look at the carbs. It was suggested to me that it could be the rectifier as these are a common fault but im not sure whether this would cause the problem im having as im a bit of a noobie with bikes
Re: running issue
Yes electrical faults are common on these bikes, all sorts of symptoms can show up with a dud system (some like you describe). The problems can be easily fixed for good though with the right parts.steve85 wrote:It was suggested to me that it could be the rectifier as these are a common fault but im not sure whether this would cause the problem im having as im a bit of a noobie with bikes
You'll need to check over a few things with a multimeter, there's a guide on how to check the charging system here: http://www.400greybike.com/docs.htm
