help rearsets
joshmega
- Bike owned: nc 30 zx6r sv650
Re: help rearsets
okay thanks
- Smev
- Bike owned: NC30 of course
Re: help rearsets
can you take off the foot peg and lever and flip the lever up-side down? it may have a bit of adjustment that way?
Mister Donut Rep NC30
- Smev
Re: help rearsets
or can the adjuster that connects the lever to the master cylinder be lengthened/ adjusted anymore?
- Jamboy
- Bike owned: 916 ,NC30, CBR600RR, RGV250M
Re: help rearsets
Mine is already on full adjustment, next step is to find a way of making the rod on the master longer.
joshmega
Re: help rearsets
here are pictures of my sets, you'll see the brake lever is far to low, and my gear change lever is really low but when i move it at the end of the rod it wont let me change gear accept from gear one unless its put on where it is on
any ideas
any ideas
- Jamboy
Re: help rearsets
Your gear lever side you can cut the change rod down, I cut about 10mm off both ends of mine. As for the brake side seeing yours has given me an idea.
We need to make another u shaped connector that is longer to allow the lever to lift up.
- Hadies
Re: help rearsets
+1 on cutting the rod for the gear lever side. Use a coupler and a threaded rod to extend the bottom of the master cylinder. Should only cost a quid or 2.
joshmega
Re: help rearsets
okay thanks mate done the gear lever, where would the best place to go to get a coupler and extended rod
