My NC30 Projects.
- Micro Monkey
- Bike owned: CG125, RVF400, YZF1000SP, 996
Re: My NC30 Projects!!
You do know that pirelli do the softer diablo H specifically for 400's rather than the Z of the rossos. It's just that they are not widely available.
Here you go, bargin £152 a pair!
http://www.sticky-stuff.co.uk/product_i ... s_id=12509
- ibby4585
- Bike owned: SP's
Drunkn Munky wrote:Here you go, bargin £152 a pair!
Reckon I will be getting these then!!
Kris
- ibby4585
- Bike owned: SP's
Back to Red/Black now!!
Lots done today. Rebuilt the rear caliper, fitted with a goodridge braided line. Rearsets on, undertray and subframe on, loom fitted back on.
Front wheel off, discs removed and replaced with a good second hand set, rebuilt calipers fitted with goodridge front braided lines. Front wheel gunk'd and polished!!
Carbs cleaned, slides drilled, rejetted to 118's all round idles 2 1/4 turns out
Half Yammamoto system with polished end can fitted, also bead blasted front pipes with all new genuine Honda studs and nuts fitted!!
Right the big one!!
Valve clearances!!
All checked and all just within the tolerances.
cylinder 1 inlets 0.12 and 0.13 outlets 0.23 and 0.21
cylinder 3 inlets 0.12 and 0.13 outlets 0.23 and .021
cylinder 2 inlets 0.13 and 0.13 outlets 0.23 and 0.23
cylinder 4 inlets 0.13 and 0.13 outlets 0.23 and 0.23
All fairly close but thought I would leave alone
Finally dropped the oil and filter and left overnight for it to drain!!
Now im knackered!!
Kris
Right the big one!!
Valve clearances!!
Now im knackered!!
Kris
marcus57
Sounds like you have been busy.
Are the valve clearances a pain to do?
- ibby4585
- Bike owned: SP's
To be honest lucky in two ways. Firstly the whole bike was stripped, no front wheel or rads to get in the way.
And secondly i didnt have to replace any shims. So actually it went ok easier than i thought it would be.
Kris
Kris
marcus57
thats how mines sitting at the moment , another job added to the list.ibby4585 wrote:To be honest lucky in two ways. Firstly the whole bike was stripped, no front wheel or rads to get in the way.
Kris
- ibby4585
- Bike owned: SP's
Honestly Marcus, just read Vipers guide before you do it. Get yourself a Feeler gauge that goes between 0.12 to 0.27 and its an hour job! Thats if you dont have to replace any shims! I reckon mine must have be done recently because they were all the same virtually!!
Kris
Kris
marcus57
i hope mines the same, my dads a mechanic so if i get stuck its not the end of the world.ibby4585 wrote:Honestly Marcus, just read Vipers guide before you do it. Get yourself a Feeler gauge that goes between 0.12 to 0.27 and its an hour job! Thats if you dont have to replace any shims! I reckon mine must have be done recently because they were all the same virtually!!
Kris
- micpec
You have done a lot, Kris! So you are glad you did your first time valve clearances? Not difficult to do. Just with good tooling and an hour time.
Rest, chill and have a nice good beer this evening
Oh, mail sent.
Oh, mail sent.
