My NC30 Projects.
- Smev
- Bike owned: NC30 of course
Re: My NC30 Projects!!
If you use a Rick O chain moving kit?!! - it moves the chain to the left by 5mm and it also helps if you run a 520 pitch chain - worth a go to fit the Dymags
Mister Donut Rep NC30
- ibby4585
- Bike owned: SP's
Smev wrote:If you use a Rick O chain moving kit?!! - it moves the chain to the left by 5mm and it also helps if you run a 520 pitch chain - worth a go to fit the Dymags
Nice!!
- Micro Monkey
- Bike owned: CG125, RVF400, YZF1000SP, 996
Think you may have to go with both the 520 and R.O kit, you may get away with just moving the sprockets out the 5mm the kit will allow but pretty sure it will be tight with just this. What is the exact outer rim width of your mag, will check it with mine, see if they are the same.
It just isn't right if something you buy, fits without probs
Kris's Outer rim measurement is a shade under 6".
My PVM's are 5.5 with 160 supercorsa's and go straight on. There RC30 fitment too i think.
- ibby4585
- Bike owned: SP's
Tony, do you think these Dymags are RC30 fitment? Can't understand this as the bloke I bought them off assures me they go straight on no problems with 160 tyres!!
Kris
Kris
Im sure they will mate, like i said mine do. I think yours are NC fitment due to the face where the spacer sits matches the NC spacer, my pvm has a slightly larger face.
- Smev
I used the Rick O Kit and a 520 chain to fit the VFR750 rear to my bike - no clearance probs at all
Plus the 520 chain is that little bit lighter so less weight to carry around or the engine to move
- ibby4585
- Bike owned: SP's
Right, I'm just gonna get the tyres and make them fit!
What are pirelli diablo rosso tyres like? Can we get them over here?
- Micro Monkey
Right i have measured my rear rim, outer to outer and would you believe it, mine is 6.5 inches wide so you will have no probs at all fitting the maxxis tyre and your dymags. You may just have to lightly sand the right tyre edge though.
Last edited by Micro Monkey on Sat Oct 23, 2010 10:07 pm, edited 2 times in total.
These are the tyres you are looking foribby4585 wrote:Right, I'm just gonna get the tyres and make them fit!![]()
http://www.sticky-stuff.co.uk/product_i ... s_id=10695
