Cost of Carburettor gasket set £76!!
fumb
Post by fumb »
Blimey, just pricing up the gasket set for the carbs. One set is £19 so for four its £76. Thats pretty steep when you only need 3 o-rings per carb when stripping to clean them.
Anyone else found a cheaper supplier or bought the o-rings elsewhere?
fumb
Re: Cost of Carburettor gasket set £76!!
Post by fumb »
I've just seen Rick Oliver does the NC30 carb float chamber gaskets for £5/set of 4.
Thats cool but i would still need the drain screw o-rings. More digging required i think.
grandpanot
Bike owned: 83 VF750, 06 Daytona, 78 bonne
Post by grandpanot »
If you think that is steep wait until you need new slides!
fumb
Post by fumb »
Oh dear i don't like the sounds of that. I take it slides are silly expensive too?
As for the carb drain screw o-ring, where has everyone else sourced theirs? Surely not everyone has forked out for the full kit when they stripped their carbs.
