diode
beefyvfr
diode
Post by beefyvfr »
my clutch diode has packed up...does anybody know where i can get a new one from.......... :(
shaun1988
Re: diode
Post by shaun1988 »
by clutch diode do you mean the little black switch that is attached to the lever?
if so davidsilver spares sale them new, they dont cost much
can some 1 tell me what this is for and if i actually need 1? as i have got ISR levers so there is no longer a place for this switch to be attached, does it have to be used? what happens if i dont use it?
Sorry for thread hi-jack
shaun
Smev
Bike owned: NC30 of course
Re: diode
Post by Smev »
I think the diode is a small block thing on the wiring loom - not far along from the rec/reg towards the back of the bike?
Smev 8-)
Mister Donut Rep NC30
hunter
Re: diode
Post by hunter »
If it's on the brake lever,then it's a a brake light switch.
shaun1988
Re: diode
Post by shaun1988 »
no this switch is attached to the clutch lever not the brake lever, i guess you guys havent got them on ur nc30? or just not noticed it lol
wullvfr
Bike owned: zx9r c1
Re: diode
Post by wullvfr »
are you referring to the clutch switch which is part of the safety circuit,meaning you can't start the bike if in gear unless the clutch lever is pulled in.
william
shaun1988
Re: diode
Post by shaun1988 »
ahh thats what it is, so its not really needed then? or do i need this for mot?
Soooo sorry for the thread hi-jack
Re: diode
don't need it for MOT.
Just means you won't be able to start the bike in gear, even if you pull the clutch in. (unless its been bypassed) then you'll be able to start it in gear even without the clutch pulled in (bad)
wullvfr
Bike owned: zx9r c1
Re: diode
Post by wullvfr »
Neosophist wrote:(unless its been bypassed) then you'll be able to start it in gear even without the clutch pulled in (bad)
funnily enough i bypassed mine on the nc30 earliy last year,cant remember why i did it but thankfully i always remembered that i had done it.....
william
