FZR 400RRSP Carbs.
1966baz
FZR 400RRSP Carbs.
Post by 1966baz »
Hello me again, Got my RRSP running yesterday :grin: ( first time in approx. 5 years as it had sat in the previous owners damp shed.) I've cleaned the carbs , all jets etc. and it finally ran on choke but will cut out if you use any revs or take it off choke. Must be a blockage somewhere . It has 32mm mukunis fitted. Any advice would be appreciated. Cheers.
Re: FZR 400RRSP Carbs.
Post by Evilchicken0 »
Renewed the fuel filter ?
There's a gauze filter on top of the fuel tap and another in the brown fuel connector where the fuel hose joins the carbs.
Try running it on a remote tank if you have one other wise it's a dirty jet
1966baz
Post by 1966baz »
Thanks again four your advice your Evil Chicken, I'll have another look tomorrow. I had it running again today and got it revving now but not cleanly. I do have a set of really clean 3EN carbs which are very similar. Possibly can try them? Cheers mate.
hunter
Post by hunter »
Sounds like pilot jets or circuit.
It does sound like a dirty jet.
I've got a similar thing on my Bimota - it's popping on the over run and flames a bit too. It's ok when I add a tiny bit of choke so its probably a dirty jet, strip and clean strip and clean .... I hate this ethanol
1966baz
Post by 1966baz »
Yeah ethanol is awful.Will strip and clean carbs again.
TechHeadFred
Bike owned: 1992 FZR400 RR (3TJ) and more!
Post by TechHeadFred »
I'm having trouble with mine, might re-test and start a new thread with detailed symptoms.
1966baz
Post by 1966baz »
Hello me again,tried a good working set of carbs tabk and airbox off my other fully working 3tj and still only recs to 4500 max.Sounds like it is hittind a rev limiter.Cant be carbs as same symptons with all my carbs.Firing nicely on all 4 at low revs Getting a bit lost for possobilities now.Any ideas would be appreciated cheers.
Sent from my GT-I9505 using Tapatalk
1966baz
Post by 1966baz »
Sorry meant tank.Just a thought, No exup valve or exup motor fitted as running stainless 4 into 1 with standard end can
Should still rev out though even if it lacks some mid range.
1966baz
Post by 1966baz »
Tried aend can off mo testriction thete.Also tried anothet CDI.Still only revs to 4500 max.
