FZR 400RRSP Carbs.
FZR 400RRSP Carbs.
Hello me again, Got my RRSP running yesterday
( first time in approx. 5 years as it had sat in the previous owners damp shed.) I've cleaned the carbs , all jets etc. and it finally ran on choke but will cut out if you use any revs or take it off choke. Must be a blockage somewhere . It has 32mm mukunis fitted. Any advice would be appreciated. Cheers.
Re: FZR 400RRSP Carbs.
Renewed the fuel filter ?
There's a gauze filter on top of the fuel tap and another in the brown fuel connector where the fuel hose joins the carbs.
Try running it on a remote tank if you have one other wise it's a dirty jet
Thanks again four your advice your Evil Chicken, I'll have another look tomorrow. I had it running again today and got it revving now but not cleanly. I do have a set of really clean 3EN carbs which are very similar. Possibly can try them? Cheers mate.
Sounds like pilot jets or circuit.
It does sound like a dirty jet.
I've got a similar thing on my Bimota - it's popping on the over run and flames a bit too. It's ok when I add a tiny bit of choke so its probably a dirty jet, strip and clean strip and clean .... I hate this ethanol
Yeah ethanol is awful.Will strip and clean carbs again.
- Bike owned: 1992 FZR400 RR (3TJ) and more!
I'm having trouble with mine, might re-test and start a new thread with detailed symptoms.
Hello me again,tried a good working set of carbs tabk and airbox off my other fully working 3tj and still only recs to 4500 max.Sounds like it is hittind a rev limiter.Cant be carbs as same symptons with all my carbs.Firing nicely on all 4 at low revs Getting a bit lost for possobilities now.Any ideas would be appreciated cheers.
Sent from my GT-I9505 using Tapatalk
Sorry meant tank.Just a thought, No exup valve or exup motor fitted as running stainless 4 into 1 with standard end can
Should still rev out though even if it lacks some mid range.
Tried aend can off mo testriction thete.Also tried anothet CDI.Still only revs to 4500 max.
