Clutch issue?
- Bike owned: RVF400 (NC35)
Clutch issue?
For info - bike is running fine, accelerates fine - no slippage, gears change fine.
That all said, the clutch feels odd. It feels like the lever isn't springing back fully, it feels "mushy" when I pull it in - it disengages ok - but, especially when engine hot, it just feels odd.
Not a lot of symptoms to work with, but any suggestions?
Re: Clutch issue?
it's just an inner cable inside a outer cable - could oil the cable (might be feeling rough), could remove the infill panel on the LHS where you can see the clutch cable attach - maybe it needs cable adjustment? (should be able to see at what point of the lever pull the mechanism starts to move
Re: Clutch issue?
I will check that out.
It is a new clutch cable - because I felt the issue coming on and thought it was the clutch cable. I didn't oil the cable though...just replace it.
M
M
Re: Clutch issue?
You could try checking the operation of the arm on the cover that works the pushrod an accumulation of old chain lube gunge grit possibly ?
