rvf float bowls
richyrd5
Regular Member
rvf float bowls
Post by richyrd5 »
what is the correct position of float bowls..drain screws facing in or out...seems to be differing opinions..for nc30/35.
Re: rvf float bowls
Should be facing in as it allows them to be accessed on the bike however in all the years ive had NC's ive never needed to access them so i have mine facing out as it just makes more sense to me when draining them off the bike.
richyrd5
Regular Member
Re: rvf float bowls
Post by richyrd5 »
thanks..yes all the ones ive seen seem to be always facing out...like you said you would need access when there off the bike..you wouldnt drain them on the bike!!!.obviously it doesnt affect the operation of the carbs whichever way the bowls are on..
Re: rvf float bowls
Its so the bowls can be emptied before storage etc without removing them
richyrd5
Regular Member
Re: rvf float bowls
Post by richyrd5 »
easier to run it dry!!
Re: rvf float bowls
richyrd5 wrote:easier to run it dry!!
usualyl itll cut out before the floats are totally empty
