Nc 30 regulator end
Nc 30 regulator end
Hi all my regulator/rectifier on my nc30 quad has decided to cook it self in to a mess. I have stripped the wires and extended them also new spade connectors with heat shrink.
The problem I have is the three yellow wires do they just go in a certain connector in the rectifier or does it not matter as long as three yellow wires are at top?? Many thanks
- Bike owned: NC35, 5SL, 3XV, 2MA
Re: Nc 30 regulator end
Three wires can go into any of the three connection holes, it's a three-phase supply.
Thank you ever so much I was afraid to plug in to rectifier .thank you
these connectors must be soldered too, criming them will make them set-fire as soon as any corssion builds up as they carry a lot of current.Bogs1980 wrote:Thank you ever so much I was afraid to plug in to rectifier .thank you
corrosion on these terminals is usually the reason they melt in the first place as they get hot.
