Valve Clearances. Give it a go! :)
monkeywithaplan
Bike owned: NC35 and NC30
Post by monkeywithaplan »
thought i would throw on this useless topic as i am bloody pleased at my losing my valve clearance virginity :D . Plus as some encouragement to any that are a bit scared at doing it.
gotta say, vipers guide is spot on, so i would suggest on following it, still handy to have your haynes beside you (i found it to be a good coffee cup mat ;) )
gave myself a whole day(so not rushed - worst you could be), lots of coffee and plenty of metallica and rory gallagher on in the background :D .
its really pretty easy, just time consuming, and a bit fiddly with only 2 shims, the front 2 cylinders outer exhaust valves, but i figured the knack for that 8-) .
now this was for what will eventually be my track bike/winter hack nc30 and only 3 were within tolerance, if at the wrong end, so after figuring which ones to swap, i am left with 6 to replace.
Image Image
Image Image
Image Image Image Image
wullvfr
Bike owned: zx9r c1
Re: Valve Clearances. Give it a go! :)
Post by wullvfr »
well done,great pics also........
william
Well done man..
Easy once you get used to it...like great sex in fact (although I don't follow Viper's guide for that :Puke: )
royster81
Post by royster81 »
CMSMJ1 wrote:like great sex in fact (although I don't follow Viper's guide for that :Puke: )
no i wouldn't do that either ,we done dave !!! :dmyspt:
monkeywithaplan
lol, no need, Haynes do a sex manual aswell :lol: , though i am not sure if the contents are for same species or man and machine :shock:
wullvfr
Bike owned: zx9r c1
Post by wullvfr »
monkeywithaplan wrote:lol, no need, Haynes do a sex manual aswell
does one self have a woman to work on :?: :?: :?: :lol: :lol:
william
monkeywithaplan
william
lol, there is regular servicing there also :lol: . though i find these particular models can blow a gasket randomly between service intervals
viper_biker
Post by viper_biker »
william
And are very expensive to run too...
fumb
Post by fumb »
One of the most satisfying jobs i have done on my Nc30. I think i had 12 out and needed 8 new shims. Made a difference in the starting and general running of the bike. It's not a had job just set aside a few hours to get it done right first time.
Sligeach
Post by Sligeach »
fumb wrote:It's not a hard job just set aside a few hours to get it done right first time.
monkey with a plan wrote: its really pretty easy, just time consuming, and a bit fiddly
its not that its hard, in fact the step by step guide is ace but it all makes tonnes and tonnes more sence when you have it taken apart and can turn the engine to see exactly where TDC is, etc.
Measuring and getting the shims out is easy, it is however an absolute funker to get the shims back in while holding the rocker arm to one side and trying to slide the tiny shim cover in molyslip into the recess. at least it is when you have fat fingers!!!
