Nc29 fuel problems
Hrcnc29
Bike owned: Sv650 R1 Ducati 748 NC29
Nc29 fuel problems
Post by Hrcnc29 »
Hi guys wondered if any could help I have an nc29 that won't pull around the 6k area
The spec of my bike is
444 Pistons
Ram air
Gf headers
B spec carbs
108 main recommended
Standard b spec needles with one washer
Standard small jet
No air filter
The bike will pull like a train with the choke fully out
Any ideas guys
dunkenb
Regular Member
Bike owned: Cbr400rr nc29 type8 NSR250
Re: Nc29 fuel problems
Post by dunkenb »
Why have you only got 108 main jets if youre running ram air etc etc ? Surely they should be bigger :o
Hrcnc29
Post by Hrcnc29 »
108 main was recommended by a knowledgeable person I have 112's might drop those in and an extra washer
tanuki
Post by tanuki »
I can tell you now to get the ram air working properly you need adjustable needles.
Hrcnc29
Post by Hrcnc29 »
I'm hopfully taking it to the dyno. The dyno guy as told me to drop another washer under the needle.
I was told that B spec carbs don't need the dynojet needles where as A spec do words from an expert
The dyno Man also said put 116 mains in. Will see what the report says
dobbslc
Post by dobbslc »
Not and expert on Onda's but if it runs better on choke then it's running lean, unless there is an underlying fault somewhere else.
Get it checked out then try it a bit richer maybe.
Davez29
Bike owned: NC29 forever
Post by Davez29 »
What's the advantage of 444 pistons, worth it for road riding?
Hrcnc29
Post by Hrcnc29 »
No it's a racebike has made a big diffrence.
Been advised to get a programmeable cdi and cams to get full potential out of it
More expense in parts and dyno time so don't think it will happen
richyrd5
Regular Member
Post by richyrd5 »
As been said.if its running good on choke then it suggests the jetting is lean.108s are way to small especially with ram air.go for 116s and go from there with dyno work :peace:
tanuki
Post by tanuki »
Hrcnc29 wrote:I'm hopfully taking it to the dyno. The dyno guy as told me to drop another washer under the needle.
I got my info from a tuner....just a couple of BEMSEE titles and the odd manx win to his name
