Flywheel Puller
Flywheel Puller
Hi all,
I'm after a flywheel puller for my NC23, can anyone confirm the thread size for me? I've seen one with an M14 x 1.5 thread but I'm not sure this will fit.
If anyone can help or point me in the right direction I'd be very grateful!!
Cheers,
Matt
Cheers,
Matt
Re: Flywheel Puller
did you get a flywheel puller, i might be needing one soon, what did you find out?
Adam
Adam
- Bike owned: zx9r c1
Re: Flywheel Puller
hello-
i can't confirm it is the correct size for the nc23 but i think it is the same size as the one i have for the nc30!!!!
and they will more than likely be the same.
contact graeme france who is a member on here,they will stock the flywheel/rotor puller
william
william
Re: Flywheel Puller
Hi guys,
After diong some research and hunting high and low for a puller that fits (after refusing to pay Mr. Hondas prices) i managed to find a bolt that would do the job. The thread is M16 x 1.5, which isn't the same as the NC30.
This link is to a website that i found, scroll down to the 'Hex fine Rotorvator bolts' and there she is, M16 x 1.5 in a selection of legnths in stock standard part. I paid less than £3 delivered, and it done the job lovely! Probably the most important bolt I've ever bought!
http://www.beeversales.com/products10.html
Just use a rubber strap wrench to hold the flywheel in the opposite direction, and wind the bolt in, might need a gentle persuation with a rubber mallet but mine just popped off!
Hope that helps.
Cheers, Matt
Hope that helps.
Cheers, Matt
