nc35 wont start
nicknc35#186
Bike owned: nc35
nc35 wont start
Post by nicknc35#186 » Thu Mar 13, 2014 7:46 pm
Hi, :P
My nc35 has been off the road for over a year and i have finally got my ass in gear and am in the process of sorting it out. The only trouble is she wont start!!! I have a fully charged battery and have checked all the spark plugs (all sparking fine) I have also cleaned the carbs but she still wont fire up! I get a little rumble but not enough to get her going. The fuel seems to be flowing fine so not sure what else to do. I cant even bump start her! Can anyone help me?
cheers :peace:
rcv4
Bike owned: 2xnc30 nc35 rd200 xt500 dt250
Re: nc35 wont start
Post by rcv4 » Thu Mar 13, 2014 9:14 pm
drain the tank and try with fresh petrol,the shelf life on modern fuel is shit.
richyrd5
Regular Member
Re: nc35 wont start
Post by richyrd5 » Thu Mar 13, 2014 10:22 pm
is the choke working.make sure the cable is opening the chokes.
nicknc35#186
Bike owned: nc35
Re: nc35 wont start
Post by nicknc35#186 » Fri Mar 14, 2014 8:35 am
The choke is working fine I've checked the fuses and I have put new fuel in but still doesn't want to know!!
speedy231278
Re: nc35 wont start
Post by speedy231278 » Fri Mar 14, 2014 12:04 pm
Vac hose on the fuel tap? Might possibly be that the carbs need a bit more cleaning?
skinnydog0_0
Bike owned: Penny Farthing
Re: nc35 wont start
Post by skinnydog0_0 » Fri Mar 14, 2014 11:00 pm
You could have flodded the bike trying to start it first time and killed the plugs.
Take them out and dry them on a gas hob or with a blow torch then try again. full choke no throttle.
racingt
Bike owned: NC35, Shand Stoater plus
Re: nc35 wont start
Post by racingt » Sat Mar 15, 2014 4:10 pm
Ditto, clean plugs. If you want go give a little encouragement, lighter fuel down plug hole, works as well!
nicknc35#186
Bike owned: nc35
Re: nc35 wont start
Post by nicknc35#186 » Wed Mar 19, 2014 10:27 am
Cheers for everyone's help but still won't start! I've completely striped the carbs put new plugs in new battery and new fuel but she still won't have none of it! Really don't know what to try next? Any other ideas? Tried full choke no throttle but nothing really happening sometimes I get a little rumble but not enough to get her going!
skinnydog0_0
Re: nc35 wont start
Post by skinnydog0_0 » Wed Mar 19, 2014 11:33 am
Are the float heights correct?
Can you try jumping it from a car - to save your battery getting killed?
Also check that your kill switch is not stuck on or shorting. Is the side stand switch ok?
richyrd5
Regular Member
Re: nc35 wont start
Post by richyrd5 » Wed Mar 19, 2014 12:57 pm
if its been standing for a while check the carb rubbers havent perrished or cracked.could be letting in air.
