Quick action throttle
Thinking of fitting 1 anyone on here got 1 if so what make did you use and are they easy to set up
Re: Quick action throttle
NSR250 throttle tube will do the job perfectly although I can't rightly remember if you need the housing as well. If you are bothered about a return cable the cbr one will be too short but as long as your carb return spring is working properly you dont need it
Brill thanks will look into it
http://www.thumpertalk.com/topic/842858 ... les/page-2
I have had a throttle stick open on me before so I like a return cable.... When you are leaving the braking late and the motor doesn't quit there's hardly enough time to cr@p yourself. But have a look at the last post of the above link.... quite an interesting explanation and it seems the guy knows his stuff
I never had a problem on the 40 or so track days I ran a single cable, I switched to a purpose built 1/5 turn throttle eventually and that was also single cable as is the one in 636.
However if it bothers you it's cheap enough to get a return cable made.
