Gearbox
Godden
Gearbox
Post by Godden »
Hi all I am a new member to the forum . I've just recently purchased a honda vfr nc30 1992
I don't know if it's me being paranoid but when I'm changing down threw the gears they seem to be a little stiff they are fine from 6 to 5 5 to 4 4 to 3 but when going from 3 to 2 it's a bit stiffer then the rest is this a problem thanks for any answers godden
VtypeV4
Bike owned: FJ1200 3CV, NC30, CX500
Re: Gearbox
Post by VtypeV4 »
Is it ok going into neutral?
To be fair, I wouldn't worry too much, the boxes on NC30 can be a little stiff from time to time. Mine is better once the engine is warm but doesn't usually cause me any bother when cold. Make sure your linkage is in good order and if neutral is an issue, check the adjustment on your clutch cable also..
Hope that helps.
rcv4
Bike owned: 2xnc30 nc35 rd200 xt500 dt250
Re: Gearbox
Post by rcv4 »
try greasing the gear lever pivot and check the linkage.
