Bike won't start please help
Weeman1234
Bike owned: Vfr400 nc30
Post by Weeman1234 »
Hi I have a vfr400 nc30 my problem is it won't start there is zero power to the bike I rode it the other day all was fine got it out today and It won't start iv charged the batterie checked all fuses and wires seem fine but still nothing I have no lights or any thing please help
bikemonkey
Re: Bike won't start please help
Post by bikemonkey »
Have you checked the main fuse in the starter solenoid?
Killswitch isn't in the off position is it? (we've all done it)
Weeman1234
Yea checked ever fuse on the bike and yea Iv done it before spent a long time trying to start it to fined I had it off lol
Have you tried jump leads? This will let you see if it is dead - fuses or what - or you can bump it.....
My money, if it was working fine, is on a flat battery
Weeman1234
Iv tried bump starting it nothing and Also put the batterie on charge still nothing
So - key in, turn it - no idiot lights at all?
100% checked the main fuse under the right hand seat panel? it is a 30a jobby..not one of the ones under pillion seat?
Morespeedvicar
Post by Morespeedvicar »
You have to get a multimeter and check the battery voltage with the ignition off and on.
Ian
Weeman1234
Silly question check it where
on the pos and neg on the battery itself...
reading with it off - should be more than 13v
then switch on...
Weeman1234
Ok thank you
