Tyga rearset swingarm clearance?
starkey
Post by starkey »
Just wondering how close the tyga rearsets should be to the swingarm and if this is normal?
Morespeedvicar
Re: Tyga rearset swingarm clearance?
Post by Morespeedvicar »
A miss is as good as a mile, but to be sure could you put a washer between the mount and the frame, give you a little bit of room. Or even file off the corner of the rearset if your desperate.
Ian
That will touch...
I use big spacers on mine - do on all the rearsets I've ever used.
^^^^This everytime. Are the spacers fitted?
starkey
Post by starkey »
yeah the spacers are fitted
28hodge
Bike owned: nc30 (track) Yam YZ250 (MX)2st
Post by 28hodge »
shim it out with a washer.
Are the rearsets new? mine where second hand and must have had a slight knock at some point as when fitted with the big spacer they touched the swing arm and rubbed it, so i had to pack it out with a washer, then got a new spacer made to the correct thickness.
starkey
Post by starkey »
yeah they are used which would explain it, will have to get a bigger spacer made up then.
cheers
