Brake hoses - standard M/C + Gold 600RR calipers
madgazman
Post by madgazman »
Hey Guys
My bike Failed its MOT :( - new rear tyre, front and rear brake discs, new rear bearings, Blow in the exhaust near manifold!!
While im ordering new Brake Discs for the front (EBC, not wavy) and pads (EBC HH), i thought would be a good opportunity to change the hoses as well, They are braided but look past it the connections to the calipers as rusted badly.
What hoses do i buy? CBR 600RR/Fireblade/SP1/SP2 onces or vfr 400 ones?
Will VFR400 fit the calipers or will the CBR 600RR/Fireblade/SP1/SP2 fit the VFR400 Master Cylinder
I bought the bike with this conversion already done, so i dont know what the original seller did.
Re: Brake hoses - standard M/C + Gold 600RR calipers
you buy the ones for the kit you have...
I bought wezmoto hoses for fireblade rrx when i did mine. Job jobbed
madgazman
Post by madgazman »
So if i get hose for 600RR/sp/fireblade calipers WILL connect to a standard VFR Master cylinder????
They reason i need to be sure is everyone on here seems to have an uprated master cylinder from a Fireblade or SP.
Thats why i was surprised to see the master cylinder on mines was still standard. Wasnt sure is the previous owner had the hoses custom made or modified is some way.
On that note what would i need to uprate the master cylinder? Is there any benefit over the standard?
the standard is the wrong size for the calipers - it is too squidgy and very very powerful.. not awlays a good thing.
the lines will fit just fine though and if you get another proper sized mastercylinder you'll be right./
madgazman
Post by madgazman »
Soz to be a pain but so this on fleebay
http://www.ebay.co.uk/itm/46250-Honda-C ... 4611201d1a
Would this be all i need or do i need the handle bar and reservoir as well? is it a straight swap over or any other mods required?
Cammo
Post by Cammo »
What bike is it and what calipers do you have?
Not all braided hoses fit the calipers, but they will fit all master cylinders. Buy the hoses based on what calipers you have.
madgazman
Post by madgazman »
I've got a 92 K reg VFR400 NC30
The owner said the calipers where off a fireblade, not sure what year but i thought that the calipers on the fireblades where the same as the SP's and 600rr's?
In regards to getting a new bigger master cylinder do i need the handle bar and reservoir as well?
