nc30 cutting out
philst88
nc30 cutting out
hello
was out not that long ago for a gd run on the bike and was sitting at traffic lights holding the clutch in and the bike just cut out. After a few minutes i tried starting it again and it started no problem. So just kept the revs up and drove home and had no problems. Then when i stopped at the house the bike was idling and cut out again. The next day i started it up again and once i turned the choke off it cut out again
any ideas what the problem could be?
TommyTheGun
Re: nc30 cutting out
Whats your idle rpm set at?
philst88
i will have to start it to find out tomorow. its the first i have ever had any problems with it cutting out.
- Bike owned: VFR400
Is the fuel tap vacuum hose ok? If leaky fuel flow at low engine speed (idle) may be insufficient as diaphram is not retracted fully.
krisztian_andre
- Bike owned: MG v35 II, NC30, MG NF Mil.
Carb balancing fixed it for me.
philst88
The idle rpm is around 1200 but the needle is constantly going up and down to about 1400 and then down to 1000. when it drops its close to cutting out then eventually just cuts out.
TommyTheGun
Sounds like you need to balance the carbs then.
