Rear hub problem NC35
solder
Bike owned: RD250e aircooled. TZR 250
Post by solder »
Hi All,
Just in from what I thought was a great day in the garage if a liitle cold. Got the steering head bearings replaced fitted the newly coated instrument bracket and re-sprayed top yoke.
Replaced the bearings in the rear hub all spinning nicely. Re-fitted, it got the hub nut on and torqued up and hub is frozen. :o
Bugger thinks I, what have I done wrong, took rear caliper off to make sure it wasn't this ......no hub still locked.
Let off hub nut and hub spins. Think to myself perhaps I over torqued it (200Nm) as per manual so loosen it off, hub spins but as soon as you torque it even over 80Nm it locks.
Used Wemoto bearings and Honda hub nut.
Too cold and knackered to think anymore about it now.... time for a beer.
Gav
Dynamohum
Re: Rear hub problem NC35
Post by Dynamohum »
Bearing spacer between bearing and sprocket carrier fitted?
solder
Post by solder »
Bugger me...........no not literally......must be the cold froze my brain, plus the end of a long day, your right, I definitely did not put it back in. :o
After 35 years of playing with bikes you might think I'd avoid this sort of cock-up. :oops:
Dementia has arrived.
Thanks :rocks:
chris nc30
Bike owned: fzr 600 r / nc30 in bits
Post by chris nc30 »
We all do daft things
thunderace
Bike owned: R6, YZF600R
Post by thunderace »
solder wrote: Dementia has arrived.
Sorry, I didn't realise it was contageous :whistle:
:lol:
hunter
Post by hunter »
:lol:
The good thing about it is,
You get to meet someone new every day. :lol:
