NC30 Hub Nut
NC30 Hub Nut
Hi all,
The rear rear hub nut on an NC30 i just got is 41mm. I even went and bought a socket to help get the damn thing off - perfect fit.
yet, the manual (akhara,.com) says it is part # 90306-MR8-000 - which is 38mm.
The haynes manual says the are not reusable so I'd be looking to get either an EOM part of a reusable replacement.
So ... what is it then? Is the part number wrong or do I have a supersized hub nut on there?
All help appreciated.
Greg.
Greg.
- speedy231278
Re: NC30 Hub Nut
The parts lists I have state 38mm for the NC30 and NC35. In fact, the NC35 part supercedes the NC30 one. Doesn't seem to be a difference between the various different lettered NC30 models, so it sounds like yours is bigger than standard. Quite an expensive nut at over a tenner plus VAT!
Re: NC30 Hub Nut
The hubnut is 46mm and the wheelnut is 36mm, they might be giving you the inside diameter on the microfhice parts.
http://www.ebay.co.uk/itm/Honda-RVF-RVF ... 43b40eb941
you can buy stainless ones off ebay but there twice the honda price
no idea why a 42 socket fits?
Re: NC30 Hub Nut
36mm wheel nut
41mm yoke nut
46mm hub nut
41mm yoke nut
46mm hub nut
Re: NC30 Hub Nut
Also kayla does titanium hub nuts that are drilled to accept lock wire, split pin, r pin, so effectively reusable.
- speedy231278
Re: NC30 Hub Nut
I thought that was the ti wheel nuts?porndoguk wrote:Also kayla does titanium hub nuts that are drilled to accept lock wire, split pin, r pin, so effectively reusable.
- bikemonkey
Re: NC30 Hub Nut
Also does hub nuts, I have one packed away in my toolbox until my dirty bike is clean enough to deserve it
Re: NC30 Hub Nut
Am i the only one that reuses the hub nut then
Re: NC30 Hub Nut
NopeDrunkn Munky wrote:Am i the only one that reuses the hub nut then
- ibby4585
- Bike owned: SP's
Re: NC30 Hub Nut
Always reuse mine!
