Help please nc21 choke
lukiooo
Hi I am in need of assistance as I am stumped! I bought the bike without the choke cable as it had a cable tie before but I had seen one on eBay so decided to change it!
I have fitted the handlebar end but I have no idea with the opposite pin goes! I can't see any catch just a pin end and at the same block it has a screw! Any help is much appreciated
Luke
Luke
Re: Help please nc21 choke
I use a choke cabl....racer chic..
However, I would expect that there is a small bracket on the front of the carbs - is there not an actuation arm you can see?
get is a pic - I don't know the 21 carbs by sight
they look nigh on similar to the nc30 carbs.
someone will find a picture.
at the front of the carbs there is an arm with a hole in it for the cble to attach to.
next to that there is a clamp to hold the cable which is opened with a screw.
