Stick coils?
				Hopefuldave
Stick coils?
I suspect the coils on my lad's 400VVT "we" are getting up and running for after his test may be iffy (hoping it's not the CDI box...) - has anyone swapped from the standard coils to coil-on-plug stick coils, and if so... which ones fit and leave enough clearance for airbox etc.?
Also... anyone know where I can get (even download) a workshop manual for it? It's a Jap-spec (restricted) GK75A model (unfaired, twin front discs).
Cheers,
Dave H. (the other one)
Cheers,
- thunderace
- Bike owned: R6, YZF600R
Re: Stick coils?
Just done a stick coil conversion on my GPX750R. Write up is here: GPX750R
I used coils from a 2007 R6 and they fitted perfectly. I suspect that your wells may be shallower though but the rubber seal can be slid down the coil.
				Hopefuldave
Re: Stick coils?
Thanks, I've done the conversion before (on my ZZR1100), so I'm familiar with the process, was wondering whether any of the coils are shorter / the right height for the 400 VVT head so that they don't get in the way of anything - I think I'll have to tour a couple of breakers with a 6" rule!
Cheers,
						Cheers,
