slightly confused
nazzurro_19
- Bike owned: Honda NC30
slightly confused
right im now going to buy some parts from wemoto for my old nc30
i was always under the impression it was a jap import so i clicked the nc30 (jap r3k), then something in my head said "check your iphone pics" and so i did and my bike code is
vfr400r3l
colour nh-1
code nh1k
so i went back on wemoto and apparently that code makes my bike a 1990-1991 european import, but my v5 says its a 1989 :S
so is it a early jap or is it a later european ,
then i went on to the colour code chart pic , sticky thing on here and i couldnt find a pic for the code of the colour which my bike should be
also i did a search on r3l , and it says they have a rear remote res for the shock and better front forks i dont have a rear remote res and i defo dont have diff forks
also it says european ones had bigger headlights but mine are the same size
so now i dont know what my bike is lol bar broken,..., haha
vfr400r3l
colour nh-1
code nh1k
- jim157
Re: slightly confused
The codes you state refers to a 1991 type 5 Japanese market bike:-
Your bike should have a remote reservoir shock and later type forks. It sounds like your bike might be a bit of a 'bitsa'. Have a read through the differences between Japapnese and UK/Euro spec bikes here and check your chassis/engine numbers against the list here.
AUTOEXEC.TWAT
It doesn't matter at all though - as your parts will still all fit.
Check your frame no against the records to see what that is - the undertray says it is a later bike, the mechanical bits say it is not.
So..it was probably built up into the bike you have now with bodywork, undertray and so on. not that unusual really..seeing as they are bloody old!
What parts you after anyways?
nazzurro_19
Im after a battery , an alternator gasket and a 35w headlight bulb
Ill check frame no in the weekend when i hopefully have a fully wOrkin bike
I'd get hold of Rick Oliver and get them from him to be fair...keep it in the 400GB
battery - YTX7BS or YTX9BS - both fit, the 9 battery is 15mm taller.
Gaskets are the same and 35w lamps are the same too..
Thats the easy-tell tale.nazzurro_19 wrote:Im after a battery , an alternator gasket and a 35w headlight bulb
UK bikes NEVER had 35watt bulbs.
Are you getting this information off a sticker from the bike under the seat? Chances are then that it's not the original rear-tray, probably been replaced in an earlier crash.
Later type (and the UK bike) have cartidge forks (theres two adjustments on the top, the silver adjuster and a brass adjuster inset into it, while the early damper rod forks only have a silver adjuster) and they also have a remote res rear shock.
All the parts you've mentioned will fit from any model though.
nazzurro_19
Yeah i was lookin at a sticker on the undertray, i see now what ya mean bu its proba off any old bike lol
If i had hair that would have been a blonde moment,
Ive mailed rick and hopefuly i can go pick the bits up saturday , i need a lOom also , im jus guna replace everything and start fresh , if i dont get a reply by friday oll give him a bell
But i know hes a busy busy bloke
