NC23 power loss after 8-9000rpm
skunk1961
Bike owned: CBR400RR NC23 1989
Post by skunk1961 »
My NC23 has developed a strange problem. :cry: She used to rev cleanly right through to 13000rpm no problem. A few days ago on the way home from work she started playing up. If I accelerate in any gear as soon as I get to around 8-9000rpm it feels like the engine is loosing spark or fuel and wont rev up cleanly (stuttering) as soon as I gear up and the revs drop she pulls cleanly again until 8-9000rpm right up the gears????????? :cry:
It started soon after changing the air filter and return throttle cable (re checked seem OK, may just be a coincidence) I have also recently replaced the down pipes the new set is slightly longer Oh yes and my speedo is sometimes wsorking and sometimes not. Any suggestions?????? :pray: Please help
:rocks:
dunkenb
Regular Member
Bike owned: Cbr400rr nc29 type8 NSR250
Re: NC23 power loss after 8-9000rpm
Post by dunkenb »
Could be the speedo restriction playing up if your speedo's on the fritz?? Does it feel like it starts running on two cylinders? :?
skunk1961
Post by skunk1961 »
Yes, it feels like one or two cyclinders are cutting out, as if they are being starved of fuel or getting intermitent spark. The speedo is in miles per hour, but the odometer seems to measure in KM (I know it is 7 miles to work, but my odo shows 11) does this make sense ??? :?
dunkenb
Regular Member
Post by dunkenb »
Sounds like a mph dial put on a kph speedo . You probably wanna do the wire splice to the cdi to remove the restriction. Should stop it cutting out.
http://www.400greybike.com/files/NC23%20Res%20mod.pdf
leopard_pagan
Bike owned: used to have a NC29
Post by leopard_pagan »
Good to see my res mod instructions still being of use. :grin:
Easy fix once you get the resistor.
