nc29 total loss - altenator/rectifier
gege
After noon lads,
I am after removing the altenator and rectifier from my track bike (NC29 cbr400) I also plan on removing the large magnet from the end of the crank.
Can you tell me the "do" and "do not" of this modification.
I know the charging is gone from the battery this is not a problem.
I was full of confidence starting this but had a nightmare
last night so can you put my worries to rest.
George
George
tanuki
Re: nc29 total loss - altenator/rectifier
Take the casing off, remove generator, remove flywheel, remove tiny woodruff key, fill hole left in casing by wire.
Bolt casing back on, unplug rectifier.
Job done.
Job done.
^ this.
ANd then revel in how fast it runs!
turn the idle up a touch too...it helps
gege
yes... yes.... o yeagh!!
Any other usefull mods i can do or ye recommend??
Pleiades
- Bike owned: 2008 R6 Race Bike
Sweet - saves me the job of asking for this info :)tanuki wrote:Take the casing off, remove generator, remove flywheel, remove tiny woodruff key, fill hole left in casing by wire.
Job done.
