HRC rear brake kit
- Deviant400
HRC rear brake kit
ok ordered a 4 part hrc rear brake res kit, it consists of a tube a spring clip a jubilee clip and a plug, i was under the impression it just replaces the standard tube with this clear one , whats the plug for ?
viewtopic.php?f=62&t=27307
- leef82
- Bike owned: vfr400 nc30
Re: HRC rear brake kit
for the top of tube i think, the clear tube is used as the resivour but ive seen others use one of those mini brembo res with it so then there aint no need for the plug.
- Deviant400
cheers leef thought as much , i got a mini pot so no probs
Malc
- Bike owned: NC35, 5SL, 3XV, 2MA
If you don't mind me asking - what do you hope to gain from adding the HRC rear reservoir replacement kit?
- Deviant400
its purley a cosmetic thing in my case, replaces the old tired looking hose from the res pot to the master cylinder. but i suppose in racing terms it sheds a fraction of weight by loosing the rear pot altogether , minimal i know but every gram adds up over the whole bike and if they can save weight they will i guess
reverse cylinder jim
Be carefull when using this mate, the clear tube sweats alot so make sure its not touching anything that it will damage.
dogmatic69
- Bike owned: RVF400 RGV250
less weight, more speedMalc wrote:If you don't mind me asking - what do you hope to gain from adding the HRC rear reservoir replacement kit?
They go hazy and sweat...waste of cash IMO....
viper_biker
Totally agree. I think they are crap, but I still have one on the bike LOLCMSMJ1 wrote:They go hazy and sweat...waste of cash IMO....
- alexwitham
I've been using one for 2 years filled with normal dot4 and never had any sweating. They do fade though but I replace my brake fluid every year and change the hose at the same time.
