525 sprockets 520 chain...help
mattUKNC
Post by mattUKNC »
Hi all,
Just come to fit new chain and sprockets, cut old chain off all sprockets changed, come to thread new chain and noticed it's a 520 chain!!! :shock:
Can this be fitted or is that never going to work.
Got the chain from GF ages ago, left a message and hoping it can be swapped...until then the bike is off the road. :(
Matt
vfrman
Bike owned: NC30, 1098s
Re: 525 sprockets 520 chain...help
Post by vfrman »
Nope. 520 is thinner than the 525. Even if it were the other way around you wouldn't want to fit a 525 chain to 520 sprockets. They must all be the same pitch.
mattUKNC
Post by mattUKNC »
vfrman wrote:Nope. 520 is thinner than the 525. Even if it were the other way around you wouldn't want to fit a 525 chain to 520 sprockets. They must all be the same pitch.
Thought as much.
Anyone want a 520 chain? :roll:
reverse cylinder jim
Do you not fancy buying some 520 sprockets and run the 520 chain?
mattUKNC
Post by mattUKNC »
reverse cylinder jim wrote:Do you not fancy buying some 520 sprockets and run the 520 chain?
Thanks for the offer but the new 525's are on already. :roll:
Speedy
Bike owned: RVF400RR, ER6n
Post by Speedy »
I'm not sure RCJ was offering to sell you sprockets, but instead asking why not use a 520 kit instead; either now or even when you're done with the 525 kit.
Speedy wrote:I'm not sure RCJ was offering to sell you sprockets, but instead asking why not use a 520 kit instead; either now or even when you're done with the 525 kit.
Spot on, just thought it might have been a cheaper option to maybe buy some 520 sprockets instead of buying a new 525 chain?
mattUKNC
Post by mattUKNC »
Ahhh gotcha, a good thought, thankfully Graeme has said he'll swap the 520 for the 525 required. Cheers.
mattUKNC
Post by mattUKNC »
All sorted, thanks to Graeme France for the quick turnaround. :up:
