nc30 suspension linkages
rgstu
Post by rgstu »
does the nc30 share the same bottom linkage as the nc35 ive changed over to a r6 rear shock and the bike seen to be sitting lower ive put the bottom linkage in correct any ideas on how to get it sitting a bit higher cheers stu
Re: nc30 suspension linkages
The 35 linkage will make it sit a little higher but not a lot. I thought the R6 shock was longer than the NC shock, did you measure the length of it before you put it in?
thunderace
Bike owned: R6, YZF600R
Post by thunderace »
Drunkn Munky wrote:I thought the R6 shock was longer than the NC shock
It is by about an inch. Shorter dog bones are needed to raise the rear end.
So the R6 shock is longer? then why is his bike now sitting lower?
arsey30
Bike owned: ftr223 650 bros
Post by arsey30 »
Is the spring preload set too soft.
The 35 link raises back end by around 15mm from memory
rgstu
Post by rgstu »
tbh i never measured them against each other but im going to take it out at the weekend to see the difference the shocky is brand new so is on standard settings
The spring will most likely be too soft for the NC for starters
Cammo
Post by Cammo »
Drunkn Munky wrote:The spring will most likely be too soft for the NC for starters
Yep, that can be the only reason why it's sitting lower if you didn't change anything else.
rgstu
Post by rgstu »
is the r6 lighter than the nc30 ? i will try a 35 linkage and wind the preload up a bit to see if that improves things if not a new spring and get some nice adjustable dogbones made up
