starting issues.
- Bike owned: NC29, FZR400.
starting issues.
hi guys, my fzr doesnt want to start, it fires up on the starter motor but as soon as i let go of the starter but she just dies. ive got all new plugs in her and have tried a new battery but nothing!, anyone suggest anything?
- thunderace
- Bike owned: R6, YZF600R
Re: starting issues.
Kinked fuel hose stopping fuel flow?
2minutes i shall check.
nope, no bent fuel lines.
- Hogdigerdy Dog
is this with or without choke?
unless it's -10, mine don't like the choke at all and dies off,
i make sure the carbs/fuel pump are primed, turn the kill switch on - off - then on again and hit the start, if the engine catches then a little bit of throttle not much should do the trick
poored a bit of fuel down the carb and she fired up, so im guna strip mi carbs down and give em a good clean, hopefully thisll do the trick.
- Hogdigerdy Dog
sounds like it could be manky carbs then,
a good clean'll sort that out and check the air filter and fuel filters as you go and see if that does the job
found that the pilot jets were blocked with red shit, so hopefully thatll be it
- thunderace
nestor-nc29 wrote:found that the pilot jets were blocked with red shit, so hopefully thatll be it
Has it been eating NCs for breakfast?
i hope not or my nc29 wont be starting either.
