starting issues.
				nestor-nc29
- Bike owned: NC29, FZR400.
starting issues.
hi guys, my fzr doesnt want to start, it fires up on the starter motor but as soon as i let go of the starter but she just dies. ive got all new plugs in her and have tried a new battery but nothing!, anyone suggest anything?
						- thunderace
- Bike owned: R6, YZF600R
Re: starting issues.
Kinked fuel hose stopping fuel flow?
				nestor-nc29
2minutes i shall check.
				nestor-nc29
nope, no bent fuel lines.
						- Hogdigerdy Dog
is this with or without choke?
unless it's -10, mine don't like the choke at all and dies off,
i make sure the carbs/fuel pump are primed, turn the kill switch on - off - then on again and hit the start, if the engine catches then a little bit of throttle not much should do the trick
				nestor-nc29
poored a bit of fuel down the carb and she fired up, so im guna strip mi carbs down and give em a good clean, hopefully thisll do the trick.
						- Hogdigerdy Dog
sounds like it could be manky carbs then,
a good clean'll sort that out and check the air filter and fuel filters as you go and see if that does the job
				nestor-nc29
found that the pilot jets were blocked with red shit, so hopefully thatll be it
- thunderace
nestor-nc29 wrote:found that the pilot jets were blocked with red shit, so hopefully thatll be it
Has it been eating NCs for breakfast?
				nestor-nc29
i hope not or my nc29 wont be starting either.
