oil in air box???
duggyr
oil in air box???
ive just removed the aie filter and found what looks like engine oil in the air filter box. it appears to be coming from the breather pipe from the black box on top of the rockercover of the rear cylinderhead dosent seem to be a leaking head gasket. is there a major problem???
the bike seems to runs to run ok except for poor tickover that is why i have just removed the carbs.
Re: oil in air box???
That's what the breather's for. Check that the oil level isn't too high (or too many monos!?), I wouldn't be concerned otherwise.
duggyr
thanks for reply cammo. took the carbs off to do your carb refurb due to poor tickover. what are monos?
duggyr
read on another forum that it could be due to worn rings or barrels or leaky valves? but this was concerning other bikes like a triumph. sorry oil level loose ok and not pulled any wheelies
it is normal - the pipe lets the oil mist in the engine breathe out and is ingested again by the motor.
Not a problem unless it is swimming in oil!
