where do the pipes go? side stand
leef82
Bike owned: vfr400 nc30
Post by leef82 »
hi all, ive been rebuilding my bike for about two years now and my memorys gona bit rusty, i pulled the side stand out of a box earlier and noticed two rubber pipes attached to it, im assuming that one runnes to the air box lid looking at at my photos i took but the other i havent got a clue, any one know? all i can see is that they both run to the left side of the genny casing upwards.
lee
thunderace
Bike owned: R6, YZF600R
Re: where do the pipes go? side stand
Post by thunderace »
Carb overflow or battery drain?
leef82
Post by leef82 »
just had a look at it again and one of the pipes has a t connector, i dont think its carb overflow their a couple of short tubes
spud
Bike owned: vfr nc30 1990 , yamaha rs 100
Post by spud »
leef82 wrote:hi all, ive been rebuilding my bike for about two years now and my memorys gona bit rusty, i pulled the side stand out of a box earlier and noticed two rubber pipes attached to it, im assuming that one runnes to the air box lid looking at at my photos i took but the other i havent got a clue, any one know? all i can see is that they both run to the left side of the genny casing upwards.
lee
yep one is the air box lid and other is the breather for your tank , well at least on my bike thats how it is
sam
leef82
Post by leef82 »
from looking at other threads, im thinking that a pipe( which i think a previous owner may of cut in half) goes from the top of the fuel tank into a t piece then from the t one goes to the sidestand and the other not quite sure....... but do the three pipes and t piece sit under the carb or above them?
spud
Post by spud »
leef82 wrote:from looking at other threads, im thinking that a pipe( which i think a previous owner may of cut in half) goes from the top of the fuel tank into a t piece then from the t one goes to the sidestand and the other not quite sure....... but do the three pipes and t piece sit under the carb or above them?
not my bike but a friends nc has the pipe from air box lid gos straight to the side stand ,
and the the pipe that comes off the tank breather which has the t piece on, the shorter pipe then sits down the left side of the alternator cover , and the long bit gos to the side stand , ive always been told there both breathers
and the pipes kinda sit between the frame and engine , i put the pipes so there just sit above the bottom of carbs on my bike
sam
leef82
Post by leef82 »
thanks for the replys i think i got it sussed now
lee :pray:
