Swing Arm Bearings on nc30
JORDAN8710
Bike owned: 1991 NC30
Post by JORDAN8710 »
Hi All!
Im away to be sending some parts away to get powdercoated including the swing arm. The problem is that im not sure how to remove the bearings from the swing arm bolt, and i dont want to be too rough incase i damage. Is there a technique or tool for removing? Any help would be much appreciated. I will be posting a full description of the rebuild on the site too.
Delboy
Re: Swing Arm Bearings on nc30
Post by Delboy »
Good luck, the side with the two bearings came out a piece of piss the other side with the one large roller bearing was a bitch!
My method.... a long drift and a BFH!!!
porndoguk
Post by porndoguk »
vfrderek wrote:Good luck, the side with the two bearings came out a piece of piss the other side with the one large roller bearing was a bitch!
i had to cut my fucker out with dremmel and then press it in
was a bitch to do!
scotjell
Regular Member
Bike owned: VFR400 NC30x2
Post by scotjell »
I'll second that dremmel is the only way to go for the needle bearing. Smash the bearing rollers out and then being careful grind through the thin wall of the bearing to make it collapse. There probably is a tool but buggered if i could find one.
JORDAN8710
Thanks for the replies. I was hoping I would get away without having to replace the bearings. Suppose it would be good practice to replace them while there out anyway eh. Do you think I'll be able to get them from honda easily enough?
thanks
Jordan
Delboy
Post by Delboy »
Get the needle bearing from Honda as it has a built in seal (read expensive, bout £50+ from memory :o easily supplied though) the other 2 are generic and can be got from any bearing supplier ;)
JORDAN8710
Thanks for the quick response vfrderek. That is very expensive :( Im going to get on that tomorrow tho so Ill let u know how i get on.
Delboy
Post by Delboy »
Look at it this way....
The origanal lasted 20 years so the replacement will do for another 20 years ;)
