float height
bullitt
- Bike owned: vfr400 nc21
float height
hi noob question i know
do you need to split carbs to measure float height
cheers
cheers
hardnutdvd
- Bike owned: RVF400 NC35
Re: float height
i dont beleive you do, there is a thread on here with a ready made tool using a credit card to set the heights.. i'll have a quick search through and see if i can find it for you
hardnutdvd
Jashdown
Re: float height
So in answer to your question, yes you need to open the carbs. The floats and float valve are inside the float bowl cover, which requires removing in order to set.
bullitt
Re: float height
sorry what i meant was do you have to pull the carbs apart
from each other or can you do them as a bank of four
to check
to check
Jashdown
Re: float height
Nope, can do it with them together.
bullitt
Re: float height
excellent cheers guys
bullitt
Re: float height
i just adjust the height for the vfr 6.8 on the card
