nc30 carbs-do i have a bit missing?
leerc
Post by leerc »
on attempting the balance the carbs i removed the tank and airbox (minging btw so that needs doing aswell) i noticed on the back of the airbox theres a lil box with 2 conectors for some sort of pipe but theres nothing there-theres nothing inside the lil box either
just below that between the 2 rear carbs theres another tube like conecter that turns freely with no pipe attatched
am i missing a few bits
lizard821000
Re: nc30 carbs-do i have a bit missing?
Post by lizard821000 »
think its your overflow filter, subfilter...... should have a small spounge in it, but lots dont. mine doesnt.
no- well, yes, some foam, .
that little box is the sub ait filter.
the hoses are overflows.
scotjell
Regular Member
Bike owned: VFR400 NC30x2
Post by scotjell »
A pic would help. But I agree with lizard mine has nothing in there either! Some pipes in that area are just breathers for the fuel tank also. Was the bike running ok before this would be my question!
leerc
Post by leerc »
i got a few pics ill try and upload them when i get home
its splutters when you 1st fully open the throttle low down
leerc wrote:i got a few pics ill try and upload them when i get home
Either the bike isn't warmed up or the carbs are not set up properly.
Off throttle it'll be mostly float-height and pilot circuitary and jets so all the tiny passageways need to be clean, pilot screws set to appropriate richness and float heights at correct levels in all carbs.
As Mark said, the small area is a sub-filter. It filters the air that goes to the throttle slides to prevent them dirtying up, it's a small piece of sponge, theres two pipes that connect this to the carbs.
