M Max derestrictor
mattiec321
Bike owned: GSXR1000K7 Monster HondaPX50
M Max derestrictor
Post by mattiec321 »
Guys,
I have brought one of these. Just a quick question. Does it plug in serial to the cdi or does it go behind the clocks?
Re: M Max derestrictor
mine went behind the clocks - unplug the speedo, plug the box in. sorted.
mattiec321
Cheers dude.
dgunthor
Post by dgunthor »
mine used to go into the CDI in the back of the tail unit (NC30)
Andy666
Post by Andy666 »
dgunthor wrote:mine used to go into the CDI in the back of the tail unit (NC30)
Same on my NC30
Same on my NC30
Depends what restrictor you are talking about..
The HRC speed off unit (and many clones) have two plugs and go in a loop with the ignition box.
The M-Max and some others only have one plug and go on the plug that originally went to the clocks (leaving the clocks plug unconnected.
You can't mess it up as all the plugs are different so it will only fit one place.
mattiec321
Right o.
the item arrived today.
It is a M Max box and has two qwhite 6 pin plugs.
I have looked at the new loom I'm goiong to be putting into my bike and it has different coloured wires to the CDI so I think I can rule out the connection at the CDI.
Cheers all
mick.mh2racing
Post by mick.mh2racing »
Same on my NC30
So did mine.
How hard can it be?
mattiec321 wrote:Right o.
Cheers all
That plugs in at the ignition box end, ignore the fact the wires are different colous.
mattiec321
Thanks guys,
I have over the last couple of days replace the whole loom, coils (Thanks Pete J) and pick up coils. I also found that the funking monkey brained plank that charge the previous owner £650 to diagnose and repair an electrical problem had chopped off connectors to the pick ups the generator and the CDI.
I have replaced the plugs on the CDI and the 3 pin on the generator, which I did not have a spare, came off the old loom and had the original female connectors from the plug opened and re-soldered on. The plugs which were on there were the spade crimp connectors. One of which had fried.
Any hoo I digress. Once all back together I spun up the engine and checked from spark at all four caps which was a success. I then pushed in the M Max box and the spark remained. So I had answered my own question in a sense.
I just wanted to be sure.
Now to tackle the carbs again......................
