NC30 Front Brake Pad Comparison - Which ones should I buy???
999Gomerz
- Bike owned: Hondas, Ducati, Suzuki, Vespa
Hi Guys,
I want to get some new pads and am after you advice on which ones, I have found part listings for the following;
1- OEM Pads: 45105-KV3-701
2 - HRC TTF3: 45105-MR7-612
3 - HRC SP: 45105-MN8-006
4 - HRC RVF: 45105-NKD-970
I am looking for an actual answer, not "I would stick with the ones that came with the bike rom the factory cause when they made it they knew what they were doing" or similar responses.
Thanks,
Adrian
Thanks,
Adrian
Re: NC30 Front Brake Pad Comparison - Which ones should I bu
The OEM Nissin pads are superb.
The EBC HH pads are also pretty good.
Goldfren/Armstrong - Shite
The Nissin oem are very good.
For the track I used Performance Friction carbon, superb (best I've used) but pricey. The best pads have probably improved somewhat since hrc released theirs for the nc's.
- CRM
another vote for genuine pads.
- mattUKNC
I use carbon lorraine ones on EBC discs, they actually work in the rain!
are these the new ebc discs then matt?mattUKNC wrote:I use carbon lorraine ones on EBC discs, they actually work in the rain!
999Gomerz wrote:Hi Guys,
Thanks,
Adrian
What is your intended purpose.
Are you planning on high-speed track/racing use or just street use?
The OEM Nissin pads are one of the best you can buy for the bike, great performance all round.
Maybe if your planning on doing a lot of super late heavy braking on a track might you consider something a bit more 'race' orientated but they often don't work as well at street temperature.
The OEM Nissin work well throught the temperature range and are good on track too.
- mattUKNC
Similar, although mine are vented.porndoguk wrote:are these the new ebc discs then matt?mattUKNC wrote:I use carbon lorraine ones on EBC discs, they actually work in the rain!
- uber pikey
OEM are my choice and once my shite pair of HH's have worn out I will look forward to throwing them in the bin, this is just my opinion and buying from flea bay
I saw it so I took it!
kevprojex
- Bike owned: ktm200exc gsxr400gk71b sv650
I have been using bendix MRR pads for a few years and i would recomend them to anyone they are just awsome.
