NC30 brake discs
Dionysus
NC30 brake discs
Post by Dionysus » Mon Oct 24, 2011 6:29 am
Hmm ... Where to start :|
Long story short rather, my fork stem seals got warn and damaged which caused a "leak" onto my front brakes which corroded the pads which, in turn, damaged my discs. Sad story, I know.
Anyway, what's worse is that NC30 discs are not readily available here in RSA and to import new ones is going to cost me about R3,500 :|
Now, what I need to know is, are there any discs that I could use instead? Interchangeable between models or some sort of generic? Because I do not have that kinda money laying around. I need to have her serviced, carbs cleaned and balanced and I need my chain adjusted, etc.
Any and all advice is appreciated.
Thanks in advance :mrgreen:
ludacris
Bike owned: NC35
Re: NC30 brake discs
Post by ludacris » Mon Oct 24, 2011 7:25 am
thought South Africa had an abundance of vfr's enough so that you wouldn't have to import stuff like that...but anyhoo you can use discs from cbr400 nc29, vtr1000f, vfr750, cbr600f, cb400sf, cbr900, Honda rs125 and rs250 and also vtr250 I think
Dionysus
Post by Dionysus » Mon Oct 24, 2011 10:07 am
Thanks.
Dionysus
Post by Dionysus » Mon Oct 24, 2011 1:02 pm
Is there a difference between the left and right discs? :?
Dionysus
Post by Dionysus » Mon Oct 24, 2011 2:16 pm
bump
amorti
Regular Member
Bike owned: CB-1, MSX125
Post by amorti » Mon Oct 24, 2011 2:45 pm
Dionysus wrote:Is there a difference between the left and right discs? :?
Depends which model you get the discs from. Some have a different drilling pattern, some don't. EG the original mega-drill discs are symmetrical, but later discs with fewer holes are different. I can't see it would do anything bad if you used them on the wrong side, though.
amorti
Regular Member
Post by amorti » Mon Oct 24, 2011 2:46 pm
Dionysus wrote:bump
It's pretty bad manners to bump your post after 1 hour. :down:
Dionysus
Post by Dionysus » Mon Oct 24, 2011 2:57 pm
amorti wrote:
Dionysus wrote:bump
Was quite urgent as someone has 2 right side discs available at a decent price :|
Thanks for the info :P
hunter
Post by hunter » Mon Oct 24, 2011 6:11 pm
NC30 Discs are stamped left and right.
