Valve clearance with KentCams
PARUS
Post by PARUS »
Just like to check - are there any difference in valve clearance if I have KenCams fitted.
Thanks.
Delboy
Re: Valve clearance with KentCams
Post by Delboy »
No, the actual valve clearances remain the same, it's the profile of the cam that has changed keeping the valves open for longer.
PARUS
Post by PARUS »
vfrderek wrote:No, the actual valve clearances remain the same, it's the profile of the cam that has changed keeping the valves open for longer.
Ok, thank you a lot.
