Valve clearance with KentCams
PARUS
Just like to check - are there any difference in valve clearance if I have KenCams fitted.
Thanks.
Thanks.
Delboy
Re: Valve clearance with KentCams
No, the actual valve clearances remain the same, it's the profile of the cam that has changed keeping the valves open for longer.
PARUS
Ok, thank you a lot.vfrderek wrote:No, the actual valve clearances remain the same, it's the profile of the cam that has changed keeping the valves open for longer.
