CBR400RRR - HRC rear brake reseviour
SPal
- Bike owned: 893, 929,SP1,NC29,
Hi,
Bought a HRC rear brake reseviour (bit of green hose pipe) to go on nc29.
I've fitted one of these to my SP1 without too much trouble ( soften in hot water & push on), but nozzle on nc29 brake master cylinder looks bigger than one on SP1.
Is there a favoured doner master cylinder I need or am I just being a pussy ?
THe TYGA website shows an NC29 fitted with the HRC reseviour but makes no mention of any need to change for another models unit?
Any info appreciated !
SPal
SPal
- petrolhead19
Re: CBR400RRR - HRC rear brake reseviour
its same on nc23, i found widening it with a screw driver or something helps get it on :D
amorti
- Bike owned: CB-1, MSX125
A little silicon grease?
tanuki
Just put it in some hot water.
matt69
- Bike owned: NC29, CBR6F2
Use a pair of pointed nose pliers to expand it a little, push them in and then open them up and then some silicon lube to fit it on.
Worked for me!
Matt
Worked for me!
Matt
SPal
THanks Guys,
I'll have another go
SPal
SPal
SPal
Hi All,
Good news, all done, had reservations that pipe would stretch over nozzle but the old boiling water trick works again
cheers
cheers
